[quote=" Dori Dori I haven't seen any fail...but then again, I don't know of anyone that races with redrilled rotors. [/quote]I know plenty of people with redrilled rotors that track their cars regularly.
Quote »BTW, how do you know they are only 'negligibly weaker'. Show me proof of that. Until then... [/quote]I'm not an engineer, just a physicist, but common sense tells me that they'll be negligibly weaker. The amount of material removed is a small fraction of the total material on the face of the rotor. In addition, the lug holes in the rotor are under very little stress -- the force holding the rotors comes from the force of the lug nuts squeezing the rotor hat between the hub and back pad of the wheel.
In my ~5 years on various 240sx mailing lists and forums, I have yet to hear of anyone who has had a Z brake rotor failure period, let alone one that could clearly be attributed to using redrilled rotors. While it's not proof, it should give some indication of how much of a non-issue it is. Quote »That's it...I got it. Since they are CNC-Machined aluminum, the drilling does not have the same detremental effect as the drilling done to cast iron...the loss of strength that is. [/quote]This is a completely moot point since cast iron is so much stronger than 7075 aluminum (the grade usually used for rotor hats, and the strongest grade in common use) -- the yield strength of cast iron is 3-4x that of 7075 Al (depending on the particular grade of iron).
Quote »I will look for them but if I don't find anything, don't assume you are right. The internet is big.
[/quote]
Unless proven wrong, I always assume I'm right -- my ego would be in shambles otherwise
Asad
