Is 97 core support same as the 95 core support?
apollo500
Car: 1996 Nissan 240SX SE
as in the title, are they the same? could i put a 95 in place of a 97, also the same question for the fender inner panel, are the same in both s14 also? i want to fix my kouki which has some pretty bad damage and cant find a 97-98 core support or inner fender. thanks in advande.
180fan
Car: 89 fastback
slight differences.
apollo500
180fan wrote:slight differences.
so does that mean i cant mix and match 97 and 95 front end parts(i mean core support,radiator,inner fender panels)?
180fan
Car: 89 fastback
the front is slightly different. Expect things not to be a total bolt up ie minor brackets, fitting, so on.
s14-240sx
Car: 1993 Nissan 240sx
They are pretty damn close, I had a 95-96 and converted to a 97-98 front end without changing the radiator support and didnt have any major issues with it. The main thing was modifying the headlight notch but that was cake work.
