is 205 65r 15 ok for 91 240sX?
vancouverbc
Car: 1991 240sx
I have 205 60r 15 on front and want to replace rear tires with 20565r 15 because the tire is more popular/cheaper. I assume that the side wall is 5% or 10 mm larger so I have to make sure it clears suspension etc.
SmithSR
Car: 240sx
Looks like you answered your own question! :) It IS taller, but only marginally so. Effective gear ratio goes up, taller gearing, but it's only a minor change.
vancouverbc
Car: 1991 240sx
Thanks.:) The 65r are 20% cheaper for same tire.
ruf-jason
Car: ur sister/mom
Smaller contact patch though. maby check 195/65/15 instead & do all 4
vancouverbc
Car: 1991 240sx
I ended up buying 60r at walmart because they would not allow me to buy 65r as it is not the mfg recommended size.
do i need the fancy 90h feature? i do drive in a lot of rain. i was thinking of buying all season.
vancouverbc
Car: 1991 240sx
i guess i will by douglas 20560r15 like last time from walmart. they said they would rotate tires and repairs are free.
ArticDragon192
Car: 91 Z32 2+2
Just remember you'll have a thicker sidewall and your car will actually sit a little higer that before. I ran 205/60-15s before and if you want the closest size to stock rolling diameter, I'd recommend 205/55-15s. A bit more expensive but they look awesome and handle better.
nismofly
Car: 89 Nissan 240SX Hatch
umm...stock is 205/60/15
how would you change to stock by lowering aspect ratio when you already are stock?
InsanityInc
stock is a 195 series tire. To keep as close to stock as possible, you want a 205/55/15 tire.
nismofly
iono my car had 205s on teardrop wheels when i got it and i thought i read that some of them came stock with 205s
InsanityInc
nismofly wrote:iono my car had 205s on teardrop wheels when i got it and i thought i read that some of them came stock with 205s
All came stock with 195s. S13s, anyway.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
205 width tires were an option.
SmithSR
Car: 240sx
true.both 190/60-15 and 205/60-15were original equipment fitment.
The 205/55-15 is an OK compromise.
nismofly
w00t for options!
eh i dont even roll on the stockers anymore anyway
ArticDragon192
Car: 91 Z32 2+2
195 was the most common width. 205/55-15s looks good. The sidewall is thinner than 205/60 and it handles better. The car understeers less when I push it.
