let5l1de »
https://forums.nicoclub.com/let5l1de-u32349.html
Sat Feb 04, 2006 6:31 am
yes it is if you are ok with rolling and pulling a rear fender for 20mm and you have adjustability all the way arounfdin the rear. its just a simple bolt on with that set-up. the front is a different story. I would say no to using that width and offset in the front. if its going to be a stock fender, I would go with a 8.5 and about a 35mm offset and maybe need a lip roll depending on tire size, ride height and camber...
i have the exact rim w/ 265/35/18 on the rear of a 89 coupe. its a little work to make the rear fit but the thin lips are the shizzy.
excuse the motorola V505 pic... ill update soon with the new lips...
