A 225 on an 8" is not a stretch. It will rub the spring. Mount a 215, or use a spacer.JDMSIL80 wrote:I'm planning to stretch the front using 225/45/17, hopefully that would work.
Thanks pal!
NO. Please dont stagger your tires if your wheels are the same size all the way around. Its just stupid. Get 215/45 all the way around. You can reduce understeer, improve tire life by rotating, and not look like an idiot with stretched tires up front and buldging tires in the rear.94_240sx wrote:It's 17x8 +38 all the way around and I have a set of 5mm spacers. I should go 215/45 Front & 235/40 Rear too?
whiterps13 wrote:NO. Please dont stagger your tires if your wheels are the same size all the way around. Its just stupid. Get 215/45 all the way around. You can reduce understeer, improve tire life by rotating, and not look like an idiot with stretched tires up front and buldging tires in the rear.
