Is 12psi safe for my setup?
kooltacos
Hi guys I have searched this but I can't find a definitive answer? I am putting together a 95 240sx with a stock redtop. The car has a fmic and full exhaust. I want to use a MBC to get the boost around 10-12 psi. Will this be safe to run with out adding more fuel via injectors or tune? Short on dough after the swap or I'd get a good wideband. thanks
Justin35ll
Car: s13 coupe sr20det
Get the car running first and drive it at 7 and make sure everythings good. Then yes you can turn the boost up to 10 - 12.I wouldn't go much higher though.The t25 doens't flow much past 14psi so I've heard.
I ran mine at 14psi with stock tune and had no issues.
But you will shorten the life of the turbo greatly
kooltacos
wow what did your afr's look like at 14 psi?
DuckyD
Car: 1995 240SX
You'll be fine. Like Justin said, start out on stock boost and everything is cool throw on that MBC and have fun.
7o7drft240sx
hey sorry to thread jack but..i was wondering if its fine to run 12 psi with the ngk bkr6eix? noob question..sorry..
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
It should be fine, but I'd still try and order some 7s. Not too expensive, and takes all of 10 minutes to change.
kooltacos
thanks for the help guys
7o7drft240sx
PyR0NiAk wrote:It should be fine, but I'd still try and order some 7s. Not too expensive, and takes all of 10 minutes to change.
alright thanks a lot
