Agreed i wouldn't settle on that. I have an 08 mt and love it although i have 40kmi and my 6th gear wont let me shift into it but I'm to busy to take it to nissan atm. Plus its 6th gear i dont careBlackMetal wrote:you just might have to bring it in to the leasing dealer and tell them in person what`s going on. at best tell them you are disatisfied with this new car experience and bust their balls...
I have an 09, and I`m not experiencing this. But I hear that this 6spd is junk, and sometimes it is difficult to get into first gear and reverse... The redline line fluid did not make it shift any smoother, so butter it is NOT...
anyways, def tell the stealership that you are not happy...
^im with stupid! i agree with both suggestionsmrodrig2 wrote:Undo the negative battery terminal for a few minutes to reset the ECU. If it's the same after driving a couple days/hundred miles or so, bring it in directly to the dealership. What they are telling you is BS, you can have problems that don't trip a CEL.
What? The 6MT that comes in this car is fine. It is certainly NOT JUNK. My trans is as smooth as can be. The OEM fluid works fine. If you are having transmission issues it's not because the 6MT is junk in general, it's because your particular transmission is not working properly. Go get it looked at. Since you have changed the fluid, I doubt Nissan would help you any further. The CVT is the transmission that has issues time and time again.BlackMetal wrote:you just might have to bring it in to the leasing dealer and tell them in person what`s going on. at best tell them you are disatisfied with this new car experience and bust their balls...
Yeah worth a try. Might be an issue with the throttle as well...DJBeasy wrote:Idle re-learn might help this???
Viper5000 wrote:Ive had that happen on rare occasion... usually a little clutch action fixes it
QR25DE wrote:If you tap the gas does the idle return to normal? Like give it a good shot. Also does it climb rpms by itself just sitting there? Would be the same as mine did if so...
Not really sure what this means. In 12 years all of my cars have been mt. Eclipse, Jetta, Mazda3, and the Altima. I've never had a problem like this.Viper5000 wrote:Ive had that happen on rare occasion... usually a little clutch action fixes it
I'm so glad someone else has had the same problem. The problem started a few weeks after I got the car. I, too, was at a stop light and the RPM's gradually kept climbing. I shut the car off, too! I haven't made any after-market alterations, so this is strictly a factory defect. Hopefully this won't be a recurring repair.QR25DE wrote:Mine was a bad o2 sensor (but I knew it was bad, we ruined it by heating it up too much to get it out when doing the turbo install) - Primary o2. After I replaced it it was fine.
I'm curious to see what fixes it in this situation.
When it happened for me it freaked me out. Sitting at a light and the rpms just kept climbing. Had to shut off the car cause I was getting scared hahaha. Usually tapping the gas fixed it but it was annoying on the highway cruising because if you let you foot off the gas it was like cruise crontrol as described...
I've had it do it a couple times since then but not as bad at all. I now blame the SAFC / Turbo setup / wiring problem somewhere or my MAF is dirty or TB is dirty.
Let me know what they find out. Most of the time it's completely fine. Hasn't done it in over 2 months.
QR25DE wrote:Ouch get them to take it for a day or two and drive it constantly. They'll be able to recreate it. OR take it to another dealership.
QR25DE wrote:QR25DE wrote:Ouch get them to take it for a day or two and drive it constantly. They'll be able to recreate it. OR take it to another dealership.
Better yet, get a passenger to go with you or setup a video cam to record it.
