bartZ32tt »
https://forums.nicoclub.com/bartz32tt-u128736.html
Sun Feb 27, 2011 11:16 am
How have you confirmed which cylinder it is? Do a power balance test - with car running, pull the connector on each coilpack one at a time. Listen for a change in idle. If no change, you found the problem cylinder(s). Then try swapping plugs/coilpacks from bad cylinder to any good cylinder. If no change, check injector resistance using an ohm meter. You're looking for 12.1 ohms iirc. Report back with what you find, but it's most likely your injector from what you described.
