niznos »
https://forums.nicoclub.com/niznos-u14767.html
Wed Mar 24, 2004 2:20 pm
Probably half of you reading this out there has this problem: that accrodian looking piece of intake tubing just in front of the throttle body is rotten or even ripped in the folds. Nissan wanted $80+ for the stupid thing but I would recommend that everyone with this problem to replace it. Don't duct tape it, or try to silicone it up, it just won't stop the air leak. the air seeping in did not pass throught the Mass Air Flow sensor, so the ECU is not compensating for it and will give a bad idle, and likely other drivability issues depending on how bad it is.
It seems that my idle was bad, at least partly, due to that tube. I got it replaced by getting a friend to buy it at jobber price. Still $60, but it was necessary. The idle cleaned up a bit.
When I was inspecting for intake/ vacuum leaks, I also found that the AIV may have been giving some reverse flow given that where the tube hooks in had some black carbon build up. Removing the AIV today, we'll see if this helps a bit more
