Ironing final issues with Q3
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
1.Let me get this straight you want to run a 50K car without a thermostat?
It has been said many times over the interior temperature gauge is not to be trusted for anything other than to tell if the car is warmed up. Even then its not even that true as with the gauge half way in the middle (9 o'clock position) the engine is only at 150*F.
3. Run the diagnostic found in the service manual.
4. Get everything else straightened out first and make sure everything will last a while. Otherwise if you spend money on a turbo and find out you need a A/T or worse then your...
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
3. slip/trac lites replace the two 89981 relays under the battery tray. lot of old posts on this.
