irb20det into s13
skyvia93GTR
Car: skyline
i dont know wut is going on i took my rb20det out of my s14 and transfered it into my s13 i got every wire set up right for the s13 but now im not getting any fuel delivered to the motor through the injectors just wondering if i messed up on a ground or wiring plz i need some help
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
If i remember correctly, make sure they are grounded and that the grey wire ( power wire for the injectors is properly getting power. Also make sure the fuel pump is working as well along with anything , Filter, Lines, Pressure regulator, etc.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
Make sure you have your fuel lines hooked up correctly to your rail. When I first did my S13 swap several years ago I hooked it up backwards because the way the rail looks I thought I war right. After I switched it fired right up.
gbaz77
Car: 240sx
nismo is right. if your positive flow for the fuel line is going into the outlet for the rail it wont work, rail inlet goes under your intake all the way to the farthest cylinder first. fuel rail has a valve that only lets fuel out of the negative flow side, and wont let fuel in.
skillzilla
Check the black and pink wire for your fuel pump too, may not have a good ground.
skyvia93GTR
Car: skyline
thanks guys i did check all of this but im still having problems im only getting power to my 4,5,6 injectors im lost
Cornloaf
Car: 1990 240sx
i believe the other 3 injectors have a harness of their own. check to make sure that its plugged in.
skillzilla
yeah each 3 banks of injectors has their own power source, check for power for those at the ECU and at the harness, could have some continuity issues.
