IPT performance transmission (1990) and dragon 3200 stall torque converter
superuber
Planning on doing the rear main. Any other suggestions from you guys?How many quarts do these hold dry?
qsiguy
Car: 1994 Infiniti Q45 Turbo
You can't post this without providing some detail on the trans! How much? Is this your old one? Replacement? Details please...I'm gathering data on my own trans overhaul.
superuber
Used 90 trans (better gearing)-$225IPT performance trans-$2995Dragon torque converter-$768
Beating a 350Z off the line-PRICELESS!
My old one comes out in a couple of weeks. Looking forward to seeing the difference. Esp with the NOS.
superuber
This will give you an idea of what they do.................
http://www.ipttrans.com/nissanauto.shtml#main
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
superuber wrote:Planning on doing the rear main. Any other suggestions from you guys?How many quarts do these hold dry?
looks nice there superbe sure you put in a NEW genuine turbine sensor.
dry--you mean before the tq conv fills up? i put 4 in the sump, start up and get ready to pour quickly.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Rick I demand a phone call once the trans is broken in and you have mad stupidity..
its going to transform your car...
BTW, its quite the change from when you were talking about selling the car to dumping more dough into it. Game set and match.
Q45- 1,532,234,234Rick- 0
qsiguy
Wow, I really need something like that. I am pretty sure I'm loosing a bunch of power through the transmission as it is now. Slips way too much, shifts are weak. I imagine it's only a matter of time before I kill it unless I do something about it soon.
There are a couple of local trans shops that have really good reputations. I need to check with them on their Nissan/Infiniti experience. New Jersey's a little out of my way...
superuber
Back a couple monthes ago I was looking at a law suit. We settled out of court and things have turned for the better!
Now I'm broke, not because of man-because of the Q!!!
Q45tech
Use a Consult to data log the launch speed vs rpm vs turbine sensor rpm in 0.03 second increments. Convert data to a graph to visalize what incremental improvements can achieve.
Up to 3-4 mph the rear differential has the highest frictional loss other than tire road interface.
Experiment with different ATF to otimize ATF temp vs frictional losses in TC.
An ideal TC would have a separate ATF supply than the the body of transmission this is the negative compromise that oem cars have.A temp [viscosity] that is good for one is bad for the other!
captainluigi
Car: 1996 q45t
dennis, please explain the desire for different temp needs between tc & trans body. thx
superuber
Turbine sensor? Do you mean speed sensor?Called Scottsdale today-Joe hooked me up!!!!!!!!!!!!!!!!!
BTW: IPT says 10-12 Qts. I'm putting in redline!
Modified by superuber at 12:03 PM 2/5/2008
qship96
Car: 1996 Infiniti Q45
Use the Redline D4, as the high temp fluid is not optimal in cooler weather, and the new D6 is thinner than the d4.
I have had excellent results using the D4 fluid, changed every 25K {overkill for this fluid},and currently have almost 209,000 miles on original transmission that still works perfectly
Also, be sure to plumb an external filter into the cooler line, either the factory one from the 94-96Q or a magnafine, or a motoroil style replacable filter.
Modified by qship96 at 11:37 PM 2/4/2008
superuber
qship96 wrote:Use the Redline D4, as the high temp fluid is not optimal in cooler weather.
I'm using the D4. Already put a filter in when I did the cooler.
elwesso
2007 BMW M Coupe
when does the trans go in?
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
elwesso wrote:when does the trans go in?
x2 that sh*t should have been in weeks ago! You see, that's what happens when you get old-patience and all that!
superuber
Next week it goes in. It's going to tie the lift up for a couple days. We have been kinda busy and we need all the lifts. Looking forward to feeling the difference. Don't worry Wes you can drive it when you come to Carlisle.
elwesso
2007 BMW M Coupe
superuber wrote:Don't worry Wes you can drive it on the track when you come to Carlisle.
Why, thank you Rick...
superuber
Hey, did I say that?I saw how you treated yours on the track last year!
qsiguy
If it survives the "Wes Test" we'll know it's strong!
elwesso
2007 BMW M Coupe
superuber wrote:Hey, did I say that?I saw how you treated yours on the track last year!
I treated it fine... I did nothing to harm it (well except maybe the excessive tire roasting)... I just use it as designed.
QShip
IPT does great work. I had them do a TC, VB and additional transmission cooler in my Titan.
The Titan put down 414 hp at the wheel.
superuber
Trany came out beautiful, having issues with the tc! I'm overnighting mine to precision. They say there are 3 different options. Should be back in friday.
I'm listing the transmission on ebay. 86K miles, if anyone is interested in it let me know. Pick up.
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
superuber wrote:Trany came out beautiful, having issues with the tc! I'm overnighting mine to precision. They say there are 3 different options. Should be back in friday.
When you posted that you were going with the PI converter, the first thought I had was: "I hope it fits without any problems."
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
What did you get and what were you supposed to get?
superuber
Well lets see, the first one was for a 240, the second was for a 300z turbo, hopefully three times a charm! Racked up $600 or so in overnights! Whats the deal with PI, sijoko?
lino
That really sucks. Maybe you should have sent them pics of your car so that they can match up the proper part. Hope you finally get the right one this time and I can't wait to see some pics!
btw congrats on the auction.
superuber
They said the Q has three different one's based on size. I sent them mine to match it up. Hopefully I'll get the right one!
I was happy about the auction, although I wanted to get $9,500.That particular model is very hard to find.
lino
Do you know what the 3 sizes are?
The SS Daytona white dial is always desirable and rare, but replaceable. If you ever need another in the future, I can help get one for the right price.
superuber
I'm not sure of the specs, but the height and bolt pattern for the flywheel was the issue. Sending it in will hopefully get me the right one!
sijoko
superuber wrote:Well lets see, the first one was for a 240, the second was for a 300z turbo, hopefully three times a charm! Racked up $600 or so in overnights! Whats the deal with PI, sijoko?
I can't really give any real opinion on Precision Industries. I just remembered another NICO member who had problems with their PI converter not matching.
