Ipod to Speaker directly. without headunit.
Post all your Nissan electronics, car audio and stereo questions here!
thekawaii
Car: box with 4 wheels
I'm trying to play Ipod music directly to speaker without CD player (headunit).
Is it possible? I know there's got to be something to get 12v from car and receive just music from Ipod and sent it to big speaker....
I have to do this cuz i can't install headunit in my car.
joe603
Car: 2014 Durango R/T
you're ???? is an amp. You could get a converter for the Ipod to send the Ipod signal via RCA jacks. Those would connect to an aftermarket amp, which is connected to a 12volt source (battery) to provide power for your speaker. The CD player has a small internal amp to drive the speaker.
thekawaii
sorry one more question
So i can control volume with Ipod right? or does amp controlls volume too?
joe603
With using the Ipod for the input source, it would control the volume. The amp has settings for matching the input gain from the source...its not a volume control.
R6_240sx
Car: 1997 240SX LE, 2004 YZF-R6, 1980 Celica GT
Get the Belkin car charger and iCharge cord so u can charge ur iPod and play music at the sametime.http://catalog.belkin.com/IWCa...49006
Belkin car charger has an output headphone jack and the iCharge cord is basically a headphone jack to RCA.
Modified by bboyp1ng at 3:29 AM 11/24/2006
Kido1986
Why can't you install a HU? Dash area badly damaged?
R6_240sx
^^I think he just doesn't want it. Or $$ problems?
Rex
Car: None
There's an older thread about this somewhere in here (Car Audio sub forum). It' suggests using a 1/2 DIN eq with either rear RCA input or front side 1.5mm jack.
In short an iPod won't have enough power to push anything more than headphones on it's own, you'll need some "amplification" and a way to feed (signal) and trigger it.
thekawaii
Kido1986 wrote:Why can't you install a HU? Dash area badly damaged?
full with other stuff... no more room. plus if small ipod will do the work, why not.
BMAR240SX
Car: 1993 Nissan 240S Coupe
Not to knock you off or anything the quality is not the same you are better off getting a radio with a aux in it. I have done this before and isnt worth it
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
Just plug the iPod into a car audio amp.
