M3Vert »
https://forums.nicoclub.com/m3vert-u40773.html
Thu Jul 06, 2006 3:27 am
Once you have the iPod plugged in, use the disc button on the dash to get to the DVD menu. On that menu screen, you will see a button on the bottom left that reads "Settings / Aux". Use the left arrow key on the middle dial to navigate to that button. When the button is highlighted, press the middle enter key and you will go to the settings / aux menu. If you do not have a DVD in and the iPod is playing, you should be able to hear it. If there is a DVD on and it is playing, you will have to select AUX on the sub-menu using the enter key again once it is highlighted. With that selected and the iPod playing, you will be able to hear it.
Be sure to keep your iPod volume at about 3/4. From there you can now use the volume on the car to control it. You will still need to select songs using the iPod controls.
Hope this helps,
Steve
