4drsleeper »
https://forums.nicoclub.com/4drsleeper-u105839.html
Fri Mar 06, 2009 6:42 am
Well, I've noticed that if the I-pod is connected, once it turns itself on the radio will always default to the I-Pod. This is true even if you just started the car and turned on the radio as you stated. It doesn't make sense to me either but that's what it does.
As for the charging part, the car should be charging the I-pod. Check and make sure the I-pod is plugged in tight...but the car should be charging the I-pod without a doubt.
Quick tip - I also have the 30g and it's a royal pain scrolling through 300 artist's to find what you're looking for. I changed the genre on all of my music to match the first letter of the artist name. Example: I now search by genre and all the artist's starting with the letter A are located under the genre titled A. Now instead of scrolling through 300 artists I only have to scroll through 26 letters. This really made life easy.
