smockers83 wrote:Installation will be the same really as you read earlier on that site. So it does come with enough wiring and the difficulty is going to based on whether you've done this stuff before and how comfortable you are in removing interior panels, seats, and drilling inside the car as per the instructions.
I agree - I did an install on my 2003 coupe of a different brand of adapter but the process should be the same. Allow plenty of time ( I would say 3-4 hours uninterrupted should be more than enough) and make sure you understand the directions and that they provide you directions to disassemble everything. Someone posted the link to the maintenance manual as a sticky to this site - this would also be a good resource to have in general. I didn;t drill - in my installation - except for the hole on the interior of the arm console to run the ipod plug through.
