qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Mon Jan 29, 2007 1:09 pm
What Jesda said, just find a socket that will fit and wire it behind the dash (or under it if that floats your boat). I've also wired directly to the cig. plug and hard wired it up if you want a permanent install. On a few I've just soldered wires to the cig plug from the XM unit. You can just never use it in a lighter socket again.
Check the old threads for install details, there isn't anything you can see if you don't want to. Depends on where you want to run your wires and install the push button activation switch. I'm still planning on wiring my activation wire into the old cell phone controls on my steering wheel as they aren't used any more. I just havent' gotten around to it. Haven't been driving the Q much lately as I am in need of some suspension work, shocks, tension rods, bushings, and when I do that I can get my Cali Customs installed
