ipod in the S model
davidbike
Car: Nissan Versa
I love my Versa (hatchback) S model. But I am finally buying an iPod and have heard terrible things about using an FM transmitter in the Los Angeles area to transfer the content to a car stereo. The FM band is so full, it's hard to find an empty station slot and there is often interference.
Short of getting a whole new radio unit (I like the look of this one, and it's just fine for me in every way short of plugging in the iPod) has anyone found a way to hardwire an ipod into the radio system. Hopefully, somewhere in the back. Idealy, it would be with a line that can be fed into the glove compartment or elsewhere out of the way when not in use.
It might not be possible, but I thought I would ask.
Thanks,
David
davidbike
Car: Nissan Versa
I should clarify one thing - I only really care about playing the iPod through the current radio. I am happy to control the iPod on the device, itself. So, I just need some kind of AUX input.
ThirstyRoss
Not sure if this would even work in your Versa, but...
http://www.bancroftaccessories...d=233
davidbike
Car: Nissan Versa
Thanks. But that's for the SL model. I have an S.
skylndrftr
Car: 07 Nissan Versa S
2010 Ariel Atom (pending...)
Your best bet will probably be one of the FM converter things...you plug it into your ipod and your cigarette lighter and it transmits on an FM frequency of your choice. I have one for traveling and in other peoples cars and it works great
cnsmike
Car: 07 Nissan Versa SL Magnetic Grey with Charcoal Interior
I have that FM transmitter problem myself. I did find a good one online though. http://www.geeks.com
My experiences with the more expensive models were poor so i took a chance and bought a cheaper one and it works great. Even though i have the Aux jack, i use the transmitter.
Mike
davidbike
Car: Nissan Versa
Thanks for the tip about geeks.com -
They have 3 FM transmitters: iriver, belkin and a third kind with no manufacturer name. The iriver is about $15, the other two are about $35.
Do you know which of the 3 you have?
Thanks.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I've had TERRIBLE luck with FM transmitters.
I ended up buying an extention to run from the iPod phone out to the transmitter so I could put it in my back window (where the FM antenna is), and even THAT didn't lead to decent sound.
I haven't dared spend money on the expensive ones because I don't see why they should be any better: they're all about the same size and have the same voltage power source and no room for a decent size transmitter antenna.
Sort of makes me miss my old cassette deck...at least with that I could use a cassette adapter and get fairly decent sound.
michelkenny
Car: 2007 Versa SL w/ CVT + Tech Package (Canadian)
I've used the Belkin one and it's garbage. The iRiver one works perfectly for me, though I was able to find a station that didn't have anything. The iRiver one can change the station in increments of .1 or .2, and betweek around 80 to 120, so you should be able to find at least one that works...
davidbike
Car: Nissan Versa
The Belkin might not be the best solution, but the company has a neat web site feature:
If you go to http://www.belkin.com/mybestfm and enter your zip code, will be give you the clearest spots on the FM dial to try. (At least that's what it's supposed to do).
michelkenny
davidbike wrote:The Belkin might not be the best solution, but the company has a neat web site feature:
That looks like a useful website for US people. But remember you don't need to buy a Belkin to use their site... just get another one (like the iRiver) and just use the frequency that Belkin's website gave you
Wings
Car: 2005 Nissan Versa
Will a Sirius radio FM Relay work? You'll have to wait for the adapters for our vehicles first but will be a good option. Will have to hook it up to something with a FM transmitter built into it though.
Nismo V
Car: 2007 Nissan Versa 1.8S 2008 Scion xB 2.4L
Check with your local Stereo shop they should have a inline cable fm modulator to run through the antenna slot, fm transmitters are not worth the trouble, but for the best ipod connection I would buy an SL radio or an aftermarket one with ipod controller built in..
heres a pic of a modulator
