XIS wrote:Happens to me in my EX35 also - it depends on the iPod. Some get charged and some dont. If yours is one that doesn't charge while plugged into your car, it will die... each time you start the car, it gets power and thinks it is being plugged in to play. Since the battery died, it goes back to the beginning.
I started using my son's 3rd Gen Nano with the OEM cable and it works great. That problem solved!
Ok, so I'm not losing my mind after all
Your explanation matches perfectly what I've been seeing. Even if I'm not listening to my iPod, and turn the car off, it seems to keep from going into "sleep" mode and then....voila.....dead iPod battery. I'd love to understand what's behind an iPod simply "working or not working" in our cars. Thinking about maybe trying a new cable if I can source one for not too much money and see if that makes any difference whatsoever.
Also, I've been thinking about trying to use the compact flash card reader as a music source. No idea whether one can present the music as "playlists" (maybe you just create a few folders as a "playlists", then dump the music you want into each?), what the interface looks like on the screen--or whether the ID3 tag info is also displayed. I don't update my music very often so I could just leave my iPod in my old 7-Series, then use the CF card in the EX. And in my wife's new Ford, I can stream Pandora or stored music via Bluetooth from my Android smartphone.
Have you ever tried the CF card just for giggles?
Thanks again for the information, XIS.....
Cheers,
Tim
