gjohnson66 wrote:As for the Brembo's, I was concerned about that as well when I bought my '05. They do look cool and all, but the one's that come on the car now will stop the thing on a dime!
The Brembos don't necessarily stop the car faster. They can simply absorb more heat due to the larger rotors which will reduce the likelihood of brake fade. While they could have simply used a rotor of the same size and stuck with a simpler single or dual piston caliper, and obtained the same results, the Brembos certainly had a marketting factor and perhaps drew some additional attention. The 05+ brakes did increase in size over the 03-04 non-brembos, but are still a bit smaller than the Brembos in both diameter and thickness. I'd speculate the Brembos weren't a significant factor in the sale of the G35's and required they charge a very high amount for brake service, which many complained about. The 350Z only has them on the Track models and now the Grand Touring(including the 35th Anniversary versions). Since these tend to be pricey versions and most liklely picked up by those that are more serious about performance and/or have the money to maintain the car, they don't have to worry about complaints in price as much. In the 03-04 models, all 6MT versions had them so even those with base models had to pay the high maintenance.
