Invisible Car Door Technology
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Dattebayo
Whoa, I remember this from about 10 years ago on here. Why did they not do this again?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
There are some notable downsides.
Primarily: you can't have a door panel. The inner door skins on those doors are just a sheet of fabric (you can see it in the video above in some of the Mark VIII shots). The fabric has to retract as the door wraps under the car, since the door hugs the rockers so closely. You would not be able to achieve this on anything with carlike ground clearance with a standard door panel since there'd be no clearance. On their "normal ground clearance" example the door is hemicylindrical and does not match the rest of the bodywork. It also clearly will not work on any RWD or AWD design or any other with anything going on between the framerails without adding a lot of height to the passenger floor.
Another is clearance. The door has to have space beneath the car to retract, and the paint is at risk the whole time. Imagine opening these doors in 6+ inches of snow.
Another is the fact that the window has to drop for the door to open. The BMW Z1 had a similar limitation, but its doors were cosmetic or wind deflectors at most, and designed to be operated open, so it wasn't really an issue.
Yet another, there's the tedium of an electric automatic door rather than a manual door. I imagine it would get very tedious and the novelty would wear off rapidly. If it's snowing like crazy, I can pop my traditional door open a few inches, squeeze in, and be on my way. With these, I have to expose the whole car to the snow before I can step in. Ungood.
It's also worth observing that all their prototype/example vehicles are very low-waistlined '90s models. On a modern pedestiran-impact-safe car (guffaw) you'd have a LOT more door to hide.
Oh, and what happens when the mechanism fails???? (How many power window regulators have you replaced over the years?--It WILL fail.)
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
I'd be curious how well those doors would operate after driving thru snow or parking on it.
float_6969
It's a novelty. If they could come up with some sort of magic telescoping material, then you'd be onto something.
RicerX
Car: '20 Titan Pro4X
MinisterofDOOM wrote:There are some notable downsides.
So my first impression upon seeing the title of the thread led to me to this one downside - not being able to drive around without pants on anymore.
Glad to see we're not endangered there.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
better view from the inside
[youtube]http://www.youtube.com/watch?v=xGRzPFUlIeY[/youtube]
