jeffq45 wrote:Thank you for your input qship96 and I understand what you're saying but I have used lights off of Japanese cars before and I'm pretty confident in my aiming skills, so I should be able to aim them so I have enough light and I'm not blinding other motorists. If all you have to offer as a welcome to this forum is negative response then I do not need your advice..
you obviously do NOT understand what I am saying if you think you can make this work.Your "aiming skills" have nothing to do with it....there is only correct aim,or incorrect aim.Why do you think auto manufacturers would go to the expense of designing different part numbers for left vs right hand traffic if all it took "was a good aim" to make them safe and effective???? Sorry,if you think speaking the truth,and pointing out your vastly incorrect assumptions is "negative" and "you do not need the advice", you are a fool who needs to educate himself further on the topic.Dont let your ignorance of the facts put other fellow motorists who share the roads at risk
See this article from Daniel Stern{if you do not know who he is,you should}
Daniel Stern Lighting
ECE/EEC Marking: Headlamp Suitability for Traffic Direction
This is a very important marking. All low ("passing", "lower", "dipped") beams are an asymmetrical distribution of light to give maximum seeing in the direction of travel while controlling glare light directed towards oncoming traffic. A headlamp intended for use in traffic that flows on the right side of the road must never be used on the left side of the road, nor must a left-traffic headlamp ever be used on the right side of the road. A wrong-side-of-road headlamp does not provide adequate illumination for the driver to see what he needs to see in order to drive safely, and severely blinds oncoming traffic. This cannot be corrected by adjusting the aim of the lamp, because traffic-handedness is intrinsic in the optics of the lamp. This means it is very unsafe to use UK-spec, Australian-spec, or Japanese-spec ("JDM") headlamps in the United States, Canada, Continental Europe or any other location that drives on the right side of the road. Many performance parts dealers are illegally importing and selling JDM or wrong-side-of-road ECE headlamps into North America, and touting them as a "performance improvement". They may or may not have ECE headlamp markings, but they are not a performance improvement -- they are a danger.
