Now, down to business.
Yesterday, my car started acting funny as I was going down the road. It was shaking and sputtering really bad like a cylinder wasn't firing. I get home, shut it off, and go inside to grab a few things. When I went back out and tried to start it, it was still acting funny, I get around the block and it dies. I kept trying to start it and when it finally came to life, it was still sputtering and when I put it in gear it died. I got it started again and gave it has and it kept running. I went to rev it up to try and straighten out the idle and it died again.
I pop the hood and start looking around and found out a plug wire came off the distributor. I plugged it in and started it. Smooth idle again! Gave it gas and it died... This time with a puff of black smoke out of the exhaust and some smoke coming out of the intake. Like a major double ended backfire. I tried for almost an hour and that was the best result.
I tried one last time to crank it up and I heard loud metallic tink come from under the hood and saw more smoke out of the intake. I pushed it home and called it a night.
I have never come across this before and can use your help. Any suggestions are very much appreciated. Thanks in advance.
