I put my rb26 build on hold for now (I don't have a build thread yet, but I've got the car, motor, etc.), will probably be starting back up on it in a couple months (1993 coupe, kaaz 2-way, stock twins, etc.).
I'm building this for autox (Street touring, (I know it's not technically ST legal but our club and fairly lenient is small and the things that don't make it legal are not huge), lapping days, a bit of drifting, and of course daily driving).
When I originally purchased this car, it had an RB26DETT in it, but it blew up on the way home from picking it up
Current Mod List:
Lightweight XTD Flywheel
XTD 6 puck clutch
Full exhaust (2.5" header, test pipe, 3" cat back)
Ebay Intake
Megan racing short throw shifter (V2)
3" radiator with electric fans
I also replaced all hoses, belts, filters, pcv valve, etc. removed A/C and egr.
Some things about the chassis:
1991 fastback
Hicas model
Hicas delete
ABS Delete
cross drilled rear rotors (front coming soon)
Solid aluminum rear subframe bushings
VLSD
Hicas steering rack (quicker ratio)
solid aluminum steering bushing
new OEM front lower control arms
Moog front sway bar end links
polyurathane tension rod bushings
Adjustable Rear Upper Control Arms
K-sport lowering springs
unknown aftermarket struts
HID conversion
Wheels/Tires:
For autox I'll be running 225/50/16 Dunlop Direzza Z1 Star Specs all around on the white rims in the pictures
Daily Driving: I have a set of stock 7 spoke rims with 205/50/15 Falken Azenis
For lapping days: Picking up a set of stock tear drops and putting 205/50/15 slicks on them.
Here are a few pictures:
After the RB26 was removed:
Engine:
Interior:
For all of the pictures of the build from start to present check out my album on facebook:
http://www.facebook.com/album.php?aid=2 ... b9fbdbfb0a
I'm hoping to have it on the road this Saturday.
More updates to come. Thanks for looking
