It's time to get rid of those 4/114.3 wheels and get your S13 upgraded!
Ichiba USA 5-Lug Conversion Front and Rear is Here!
A Lot Of S13 Owners are waiting for this upgrade, so don't wait!
Front: Buy It Now $299
Rear: Buy It Now $299
Again, This is not a pre-order or group-buy. You don't have to wait, they are all in stock & ready to ship!
Product Photos:
Before & After:
Installation Photos:
Description
Introducing the Ichiba 5 lug conversion hub for Nissan 240SX S13 89-94. Super lightweight & strong material for better traction and quicker acceleration. Perfect for those street drifters on a budget and even tough enough for pro driver's expectations.
Mild steel construction, utilizes OEM bearing with OE length wheel studs. All components machined for perfect fit and optimum performance.
Installation is a snap, making even the novice mechanic install with ease. Whether you are trying to expand your wheel options, drag racing or drifting is your thing, stop wasting your time with those other kits or trying to modify factory parts, install your Ichiba 5 lug kit now!
Front Hub:
OEM bearing & lightweight designed Standard Wheel Studs Mounted Stage 3 entirely designed in-house bearing Compatible with all kinds of slotted rotors & spacers
Rear Hub:
Nissan Factory Hub OEM Hub Bearing Inserted CNC Machined for precision and accuracy Standard Hub Studs Mounted Easy Installation - Plug & Play!
Modified by
http://www.ichibausa.com at 9:08 PM 5/21/2006
Modified by
www.ichibausa.com at 1:14 PM 1/10/2007
