s13conv »
https://forums.nicoclub.com/s13conv-u7851.html
Thu Sep 09, 2004 3:04 am
I just bought a CA so I thought I post an intro since you'll likely be hearing from me a bit.
I have an 89 coupe that I converted to manual last winter. Now I'm putting a CA in.
I don't plan to go crazy with it. I already built a '91 galant VR-4. Since it comes with the stock IC and piping, I plan to use that for a while. Other than a larger fuel pump, O2 pipe, 3" down pipe, test pipe, cat back and boost controller, maybe an SR t25 will go in.
The 240 is so light compared to the 3200?lbs of my galant, that I think that the power from the CA w/ the bolt ons above will put a smile on my face.
As far as maintenance before the install, I will likely change the timing belt, water pump, acc belts and fluid. I'm not sure how necessary it would be to change the head gasket and bearings.
