S13GUY wrote:Ive been had my license since June so i think im doing well. I do have another question though, on my new clutch theres like bad recoil (bc of my inexperience) when i push in the clutch all teh way to shift gears, but i shift a lot better when i barely press the clutch in and shift. Is it ok if i just do that bc i shift better or would that wear down my clutch more?
Maybe I'm misinterpreting what you're saying, but it sounds like you're letting your revs fall to low when you're shifting. Just keep practicing, and your shifts will get quicker and smoother. I was always taught that you want to keep your clutch at the friction point for the shortest period of time possible. This will prevent premature wear.
Try giving it a little throttle as you're letting the clutch out if your revs have fallen too much. This should keep your revs up and prevent the lurching feeling. I always try to clutch all the way in when I shift.
Let me know if I've totally misunderstood what you were saying.
