apparently a 17x8 27mm will clear, depending on the tire size, and type of coilover. I know my 17x7.5 30mm will
and thats 9mm closer to the strut housing, according to the calculator, assuming the stock wheel was 15x6 40mm offset.hope that helps.-chetkeep in mind the rule of thumb is just a general guildine I made up to keep people from buying wheels with far to high a positive offset, and to give you an idea of what the offset should be for the front(the rear has much more room).
