Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Wed Jul 20, 2005 5:02 pm
Swap the whole manifold including injectors and fuel rail, the GTiR has the 54C internals like the black top engines. The rods supposedly are even stronger than the OEM 54C units in the GTiR, but rods are not the SR's problem for the most part.
The GTiR does have solid lifters, but you will need to take everything off of the GTiR head in order to match tolerances, even then you more than likely will need to re-shim the head.
The stock turbo on the GTiR engine is also larger. It has a bigger cold side than the S14/15 turbo but the hotside is smaller. Swap the T25 housing onto the turbo and you'd have a solid 300whp turbocharger.
