float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Sep 03, 2006 7:09 pm
The only reason to need an external boost wastegate is so you can run low boost on a big turbo. If you plan on running high boost, it shouldnt' be a problem. But, as was stated before, external's tend to be less prone to boost creep as well.
If you're building from scratch, I'd plan on an external. I've heard problems arising from plumbing them back in, ESPECIALLY if it's plumbed back in at a 90* angle.
Being one to never put too much effort into anything, as simple is always best, why don't you vent it externally, but install a small muffler on the dump line so that it's quite. Best of both worlds...
