hw713713 »
https://forums.nicoclub.com/hw713713-u178452.html
Thu Feb 24, 2011 7:24 pm
OK long story I will try to make this as short as possible. Just bought the Truck w/200,000 miles and it was running fine, just had the initial rattle at start up, so I took it apart to change the timing chain, once I was in there, I noticed the timing chain was in great shape and had recently been changed. I put it back together without removing any of the timing components except for the distributor. Put it all back together and started it and it had a internal engine tick. Advanced the timing to 10 and it went away and started to run good. 2 weeks later the internal engine tick is back. It last for about 5 min and then it goes away, it may take it two hours of running to start, or sometimes simply at startup. The only consistency is that the check engine light comes on and the tick starts then it usually goes off when the tick stops. I thought that it was a sticking valve, however the truck runs great when it is ticking. Please send all suggestions, even if it does include a good mechanic in East Texas :>)
