Internal Clock on dash - Infiniti M
colonid4990
Car: 2003 Infiniti M45
Question is the Internal Clock on the dash above the tape deck supposed to light up. If so how do i fix it? Thanks....
CakeDaddy
Car: Y34,Pathfinder SE, Mercedes CLK500AMG Sport Pkg & A Fleet of Premium Avis Rental Cars
yes, it does illuminate(sp) this may be a bad question, but did you try turning that little wheel knob all the way up near the mirror adjustment?
szh
Car: 2018 Tesla Model 3.
Welcome to NICO!
Which model year are you referring to, btw?
Yes, the clock should light up. It is controlled by the same light dimmer as the other panel lights in my 2003 M45. If it does not light up at all, the bulb for it may be out (this is a swag, as I don't know whether the light on the clock is a separate bulb or is fed by an optic fiber from another location).
Z
colonid4990
Thanks for the assistance...But I think the Bulb is out like you said, do you know if there is an easy way to remove the clock without having to take apart the dash or is there a fuse that controlls this clock...Again Thank you...
