eddiec »
https://forums.nicoclub.com/eddiec-u12233.html
Tue Mar 15, 2005 12:35 am
i shaved my antennae and searched for those other kits and found they all cost more than i want to spend. basically all you need is a piece of wire and a way to both hook it to your radio (plug) and a way to attach it to either your window or somewhere else.
since you already removed the old electric ant., then pull the wiring for it and run it up your a-pillar and use your choice of adhesive to attach the wire to the top edge of the glass. at least this is my plan once its comfortable outside to do so.
