Import_Ant wrote:
well the injector rings only seal the injector to the fuel rail, and the tip of the injector in the intake plenum.
if the o rings are leaking between the injector and the fuel rail you will leak fuel granted, but not INTO the intake plenum. it'll just go everywhere around the injector. if the ring between the injector tip and the plenum were to leak, it would only leak air from the plenum. it could be a source of a boost leak per se but in that aspect it could cause the motor to run rich. you would also only see this problem while the motor had positive pressure (boost).
regardless I'd say pull a spark plug or two. visually inspect it and smell it. That'll get you a step further at least in trying to find your problem.
hopefully that will help you out too.
This untrue.
I had torn some injector O-rings when installing my 370's and the car ran fine for about 10mi. After that, it began chugging, backfiring, stumbling, puffing white smoke, etc. I pulled the injectors, replaced the O-rings, lubed them properly with axle grease and have had no problems since. And there was not a single drop of fuel outside the rail.
If you're not running an oil restrictor, you're going to damage your turbo seals. I did the same thing, but the damage was already done when I put the restrictor in. It helped, but I still get a few puffs here and there.
