Intermittent RPM gauge light bulb in 2010 Rogue
hotrodjohn71
Car: 2010 Nissan Rogue
Our 2010 Rogue has an intermittent working bulb in the RPM gauge in the dash cluster where the zero and one are. Sometimes it will be on and sometimes it will be off. Any suggestions before I start tearing into this thing? Thank you
Rockhoundrob
Car: 2009 Nissan Rogue SL
Just my opinion, but I would think about replacing all the other bulbs too, since they may go out soon.
The car being 14 years old.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
They're not bulbs on a gen1 Rogue, they're LED's. The only repair is to disassemble the cluster and retouch the solder joints, and that doesn't fix it, solder a new LED on the mainboard. Short of that, the cluster has to be replaced.
hotrodjohn71
Thank you.
Return to “Rogue Forum”
