Hello,
I have been absent from the forum for awhile, as my car has been running smooth! My apologies. Perhaps this is Karma kicking my butt.
On to my problem. Over the past few days, I have noticed my car, a 1995 Ininiti Q45, will occasionally backfire (sounds like it is coming from tailpipe). In addition, there are times when it feels the car will not shift into 3rd gear. The RPM will go above 3 or 4, but the car will not shift. This is not a constant symptom. Transmission fluid levels are fine. Also, I've noticed occasionally when I start the car, the RPM will go up to 1000, and then down to 0. It hasn't done this though for a couple of days.
In the past, I had these issues, along with poor gas mileage, constant stalling, and black smoke coming from the back of my car, and the problem turned out to be the Mass Air Flow sensor. I had a remanufactured MAF installed about 3 years ago.
Could this be the MAF again? Should I clean it? Just a thought, my neighbor kid decided a few days ago (before all this happened) to give my car a wash. I didn't think anything of it, until I came outside and saw him shooting water up the tailpipe. Could that have caused any of the problems?
COINCIDENTALLY, (or perhaps not), my TCS OFF/SLIP lights come on after a few seconds to a few minutes of driving. Most often than not, the ABS light will come on as well. Here's the kicker, the ABS will work great, until the TCS OFF/SLIP lights come on, then the ABS light will come on, and voila, no more ABS.
I live in Southern California - I'm not too worried about no TCS, but the ABS worries me quite a bit.
Are these problems/symptoms perhaps related?
I understand I own a luxury car, and as such, have a responsibility to the car. But realistically, I am currently unemployed, receiving unemployment. I don't have the luxury to take the car to the dealer, and spending hundreds if not thousands of dollars to repair it.
I greatly appreciate anyone's advice. I'm willing to clean the MAF if necessary, as I've read many times people will replace their MAF when they could have cleaned it for $6-$10. Is this true?
Thank you very much for taking the time to read this. Greatly appreciated.
Regards,
Eric Jon Olsen
1995 Infiniti Q45
[email protected]
