PEZi wrote:Well, the one in this case that wouldn't be cutting it is the one to the intake mani. You want the engine grounded, but moreso the block. When its going to the intake mani, you're only grounded to the block via the head bolts and the head gasket is acting like and insulator of sorts. For reference, the custom setup I did to correct mine is a splitter off of the negative post, with one 2GA cable going to the frame directly, and one going to the block and starter (bolted in using one of the starter bolts). Fixed mine. Will help any car in any situation... but will it fix your problem? No guarantee... but worth a try? If you can source the cable cheap enough, hell yes.
I just stripped the loosely fitting clips on the ground and just wrapped it around places it clips with some electric tape.danshaz82 wrote:mines doing it just as bad as before. i think im just gonna get a new ignition switch.
the ignition switch?Dittoz7 wrote:I just stripped the loosely fitting clips on the ground and just wrapped it around places it clips with some electric tape.danshaz82 wrote:mines doing it just as bad as before. i think im just gonna get a new ignition switch.
Little ghetto until I get time this weekend to do it right.
