Intermittent misfire 1994 Q45a
morton27
Car: 1994 Infiniti Q45a, 1988 35th Anniversary Corvette, 2002 Lincoln Navigator, 2004 Dodge Ram 1500, 1988 Volvo 240
I reposted this here from the general infiniti post to get more replies, hopefully.--------------------------------------------------------------------------------
My 1994 Infiniti Q45 has an intermittent misfire at start-up. I plan to check plugs and injectors any other ideas? Car has 168,00 miles.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
And a summary of the recent maintenance history is?
A power balance test will tell you a lot.
Desmoquattro
Car: 1991 Infiniti Q45
1997 Ducati 916
Start with cleaning the MAF, the throttle body, and REPLACING the spark plugs (checking is never worth it, especially on the Q which takes so much labour to do. And usually it's hard to tell when a platinum tip plug is toast, unlike a copper core plug). Simple stuff first. Then do the easy injector / knock sensor resistance test outlined here:http://www.q45.org/ohminjectors.html
Mine ran quite badly when cold when I first got it, and stalled a lot. The guy who sold it was afraid it was a fuel injector that had gone bad (he had already replaced a couple, as well as the O2 sensors and the knock sensors). After cleaning the MAF, putting in a new air filter, cleaning the throttle butterfly, and replacing all the plugs, it starts and runs beautifully even in -10 C weather.
