Intermittent low idle at start - engine noise when under load - connected?
iCapture
Car: 2011 G37S
Hey guys,
11' G37S owner here. So every now and again when I start the car the idle goes really low, and on very few occasions has shut off. I figured this was a MAF issue.
But there is one other issue going on and I was wondering if they are somehow connected. When under load at low RPM's, for instance when I'm just driving casually and a big hill comes around, when it slowly press the accelerator a weird noise comes from the engine. Its not exactly a knock, but kinda sounds like it. When I drive up hills at a high rpm the noise is absent. It also could just be that the increased volume of the engine is drowning it out.
I was wondering if this is a known issue and if it could be connected to an air flow issue? I am selling soon and I'd like to get everything working lovely before that time.
centralcoaster33
Car: 1997 Nissan 240SX #5
Have you checked your cars computer for codes with a scanner of some sort? You can use your own, borrow a friends or co-workers, or go to a parts store like AutoZone and have them scan it for free. If no codes, check your fluid levels for everything, have your battery and alternator tested, look for vacuum leaks, disconnected hoses, wires or sensors. Finally, consider any recent repairs you may have had (like throttle pedal or sensors). Please let us know what you find or remember.
