tpjockey »
https://forums.nicoclub.com/tpjockey-u263926.html
Mon Jun 06, 2016 5:23 pm
The final chapter, (I hope).
So, after my local mechanic replaced "two cam sensors and the crank sensor" twice - first with aftermarket parts and then with OEM Nissan parts, I still had the problem described. So I then went to the Infiniti dearlership in Columbia, SC, d!ck Smith Infiniti. There, they replaced the "crank position sensor", part # 23731-4M50B 23731M, located on the front of the engine on the driver's side below where the "cam" sensors are. (That is the sensor that prior respondents had pointed to, to their credit and I thanks them.) My problem appears to be solved. I went back to my local mechanic to acquaint him with what the Infiniti dealership had done. And here is where things get very interesting. My local mechanic looked up the Nissan OEM part number for the "crank" sensor he had replaced and it was an EXACT match to the one the dealer had replaced! But my local mechanic said the crank sensor he replaced was on the BACKSIDE of the engine, not the front. While I was there, my local mechanic called the local Infiniti dealership, in this case in Augusta, GA, and inquired into why their prior guidance had not identified the sensor on the front of the engine as the "crank" sensor. From what I took from listening in on this call, the M45, at least for the 2008 model, has TWO identical sensors, with IDENTICAL part numbers, associated with this engine, one on the backside of the engine and one on the front side. I can't say for sure but, I'd give this a 95% chance of being correct.
To his credit, my local mechanic told me there was "no charge" associated for the additional work he had done. Still, I had paid for the replacement of two "cam sensors" and one "crank sensor" at aftermarket prices. There were no further charges for replacing these three parts again with OEM NIssan parts. So, I guess, all in all, I have confidence that my problem was solved and maybe also have some new parts on my car that, technically, were never really needed. But, hey, life has its twists and turns. I'm not pissed at my local mechanic. He did his best with honest intent and then did okay by me regarding his charges for his work. I hope this information proves useful to the next M45 owner with a "P0340" error code.
Good luck and thanks again to all who responded to my posting.
