ae7456t »
https://forums.nicoclub.com/ae7456t-u172554.html
Wed Feb 22, 2017 7:32 am
This is a continuation of an ongoing saga, but the issue has changed, so starting a new thread.
Recently I had my transmission swapped with a used one...In the course of that swap, the car developed quite the electrical problem with a ton of lights coming on, when the car is started, and hard shifting when put into gear. The shop cleaned off a ton of ground locations, and replaced the IPDM, and presto, the lights were gone, and the car ran great.
The car ran great for 1 week, then, Sunday, I took the car out, and the lights came back on, along with the hard shifting. I shut the car down, paused, restarted it, and the lights were gone and everything ran great. Same thing happened on Monday, but the lights reset when I shut it down, and all was good.
Tuesday morning, the car would crank but not start...I eventually got it to start, and immediately got the following...Tire Pressure Waning (!), VDC Off, ABS, Brake, Slip, AWD, AFS OFF, blinking SES (code U1000), no shift position indicator (PDNR), Tachometer that would go to "0", then back up to 800, headlights and dash lights that would turn themselves on/off, radiator fan that would turn itself to high, then back off, and probably a few others I have forgotten...The car seems possessed, quite frankly.
I disconnected the negative battery cable, and left it for the day. When I came home that night, I reconnected the cable, started it, and got all the same lights. I disconnected the negative battery lead, again, and took off the passenger side glovebox/dash. I found a wire bundle that looked like it was supposed to be attached to a bolt, near the BCM, so I reattached that massive connector...Right afterwards, I reconnected the battery, started it, and all the lights were gone...Back to normal!
Thinking I had solved the problem, I shut it down, buttoned it all up, started it, and, again, all was normal...Drove it to the grocery store, shut it off, came back out of the store and it started right up...Everything normal.
This morning, with an air of overconfidence, I got in, pushed the button to start, crank but no start. Second time, crank but no start. Third time, start, but all of my favorite warning lights and symptoms from above are back. Disconnected the negative battery cable, and left it.
I am seeking the collective wisdom of this forum, but here is what I am thinking, as I am grasping at straws:
1. Grounding Issue - Something under the passenger dash (or elsewhere) is intermittently not grounded.
2. Wire Shorted - Something under the passenger dash (or elsewhere) is intermittently shorted.
3. ECM - The ECM is going bad, but occasionally keeps it together long enough to run
4. BCM - The BCM is going bad, but occasionally keeps it together long enough to run
5. Battery - The battery (2.5 years old) is flaking out, when it sits overnight, causing the gremlins to return.
While it is cheaper for it to be 1, 2 or 3, they don't explain why it would work for long stretches (a full week), but then fail, now, when it sits for 12+ hours.
Sorry for the long post, but, as always, looking for other options and hoping to help future generations that encounter the same problem...As always, I will let you know how the troubleshooting progresses.
EdBwoy on Sat Oct 14, 2017 10:25 pm, edited 1 time in total.
Reason: Updated title
