Intermittent driver seat
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
A while back I found the auto driver seat is intermittent, about 50% of times it moves to preset position when key is inserted, or I need to press the memory seat button to activate the seat to preset position. The seat motor has never failed over 20 years.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You can find a complete description of the ADP system starting on EL-225 here:
https://www.nicoclub.com/service-manual ... 2%2FEL.pdf
If occasionally the seat also fails to respond to the manual buttons or seat switch, then you probably have bad brushes in the motor. If not, the most likely culprits (probably in order) are a worn Key Insertion Switch, poor/corroded connections between the switch and the Seat Controller, or bad motor-driver hardware inside the Controller. On older controllers, the latter is often a DPDT relay that can be sourced and replaced on the circuit board.
QX4ME
11 MB C300 Sports
06 Honda Odyssey
Thank you for the reply. I will check them.
