Intermittent bogging issue
ryan15
Car: 1990 240sx
OK, my SR is having a problem from time to time, maybe once every week or two, when I get on it it will just cut out like its hitting fuel cut when I get into boost.
I am running 15lbs, I do not have boost cut, and I think it might be my tps any ideas?
My mods are 550cc injectors, romtune, z32 maf, 255lph fuel pump, s14 t28, fmic, TBE, 1st gen dsm BOV recirc`d if it it helps....
Ryan
Emperor_Tha
do u have a wideband? At what rpm does it cut?
Things to check or doclean mafcheck for boost leak. Most of the time where the hot pipe meets the second pipe goes loose but not fully seprated at the clampcheck spark plug gapcheck fuel pressure
