I've had my S14 for about a month and a half now. It has about 163k miles and runs strong. I've noticed, however, that on occasion it will emit a puff of blue smoke when taking off from a stop light. I've burned through about a quart of oil over the course of the last 3000mi.
I've done a compression check and I'm seeing an even 190 across all cylinders.
The thought of valve seals crossed my mind, but when I decelerate hard from like 6k rpm down to 3k rpm in 2nd gear I do not notice any smoke at all! Even when it will puff at stop lights...
I may go an entire week without any puffs, but then some days it'll do it.
It never smokes at cruising speed.
Anyone ever experience this?
I'm thinking a semi plugged PCV system whose valve sticks on occasion is leading to my intermittent blue smoke puffs... That or a gummed up piston ring that gets stuck in its land from time to time...
I plan on running some Seafoam through my crankcase before I change the oil tomorrow or Friday to see if that helps at all.
Any ideas/suggestions?
Thanks!
