Intermittent battery light on
tjrob2000
Car: 2007 Infiniti G35 Journey sedan
2007 G35 Journey sedan.  A few months ago the battery light came on and when I put a voltmeter on the battery with the car running it was at 11.9vdc so I suspected the alternator since I had recently replaced the battery.  Got an alternator from a local rebuilder/reseller in San Antonio (a new Hitachi part, not rebuilt) and installed it and all was well for awhile.  After about 3 months or so the battery light came on again with the same voltage reading.  Thinking I got a faulty alternator I removed it and took it back to the vendor.  They tested it and it looked fine with current up to 160A.  I got to see them test it so no faking it.  Put it back in and all was well, or so I thought.  IIRC the voltage was in the 13.5 - 14vdc range.  This was somewhere in the september timeframe.  Since then the light has been coming on anywhere from every few weeks to a few days.  It goes out after a few minutes of driving and starting is normal.  I've had the battery tested, as well as the starting and charging systems, at an Autozone (where I purchased the battery) and nothing has been found.  I know those systems are not the best diagnostic tools, but I haven't had time to get it to a shop.  I suspect the battery since the voltage most times I've checked is around 12.63vdc which is typically low.  Looking for anything else I can check before going to a shop and have them tell me it's the battery.
telcoman
tjrob2000 wrote:
Sun Jan 20, 2019 10:32 am
I'm on my third Infiniti and have purchased two batteries on my previous vehicles from the dealer. I've found that dealer prices on batteries are roughly twenty dollars higher than independent shops but they wash and vacuum your vehicle and everything works when you leave.
It is possible you have a defective battery? Use a battery hydrometer to test the individual battery cells
Telcoman
tjrob2000
Got some time to do a little further checking and found there is a 1A current draw with everything off. Some research suggests the "normal" draw shouldn't be more than 85mA. Guess the next item is unplugging things to see where the draw is.
tjrob2000
So, I made a small mistake in my initial troubleshooting.  I had a door open and therefore the interior lights were on which is why I was seeing a 1A draw.  Took care of that issue, but I still have a 147mA draw until I remove the room light fuse then it drops to 80 - 87mA.  I'll have to look through the wiring diagrams (Haynes manual, FSM's don't have this) to see what the culprit might be.  For now I'll just go without the interior lights.  Still, 147mA doesn't seem high enough to drop the battery voltage that much unless over a period of several days.
tjrob2000
So this problem went away for several months then yesterday evening the light came on and stayed on all the way home (39 miles). It was fine in the morning when outside temp was about 70 or so, but no good once temps dropped to 50's? I am thinking the battery and a test I think that will prove it is to hook up to the battery on my other car and start it and if the battery light is not on and alternator output is good then it's the battery. I'm not 100% on this, but it makes some sense to me.
tjrob2000
To continue this saga, I charged the battery and still have the light and low output. Removed the battery and alternator (alternator is 14 mos. old, battery ~18 months) and had both tested at a local NAPA. Both test good. While there I got a negative cable since mine wasn't as tight as it needed to be (yet was as tight as I could get it, perhaps it's the whole problem). Anyway, the old cable is routed through what looks like it might be a current detector (Go to the link below to see the pic). I had to cut the old cable to get it out as neither connection end would go through and, of course, the new cable won't fit through either! Grrr…. So, what I need to know is does the negative cable have to be routed through this device? Tom
https://i1172.photobucket.com/albums/r5 ... 122026.jpg
tjrob2000
Well just when I thought this problem was gone it rears its ugly head. Ended up driving most of the way to work with the battery light on when the car started slowing so I prepared to hopefully get it off the freeway into a shopping center parking lot. Put it in neutral so I could coast longer and when the engine revved slightly the battery light blinked. Revved it to about 7k rpm and it went out and I was able to drive it the remaining 3 miles to work. I rechecked the ground cable and found I could move it on the post. Tried tightening it and can still move it. I'll check later for a different post connection for the ground cable in case I got the wrong size, but still wonder about the alternator (even though it tests good every time, but once) and the IPDM. Anyone know a good check of the IPDM? I don't have the FSM's here at work.
Tom
tjrob2000
Update. I started the car Monday to move it and the battery light stayed on. Checked output and it was 11.7vdc again. Took it to our local shop yesterday and while at a light on the way I revved it to redline and the light went off. Output is 14.3vdc constantly now. They could not get it to fail. Thinking of taking it to a shop in San Antonio that's owned by a former Infiniti mechanic. Perhaps they have some other diagnostic equipment our local guys don't have. Trying not to just throw money at it. Getting frustrating.
tjrob2000
So, two independent shops (one owned by a former Infiniti mechanic) have found nothing wrong. Alternator is charging at this time. Maybe time to talk to a dealer? Hmmmm.......
tjrob2000
Thought I'd update with a couple more symptoms. One, when the battery light is on (alt. not charging) the brake light is on as well. Also, I've noticed more often the drivability from a stop is not as good as it should be. It's like it loses the idle air volume learning. Overall performance is still fine, but off the line it has the hesitation like it needs to be re-learned.
It's hit or miss if the light will go out immediately after start or if it will come on sometime while driving. If it is on it pretty much always goes off if I rev the engine high, often to redline, then it stays off. As I recall (I should've done like I do at work and written things down in a log of sorts) this started shortly after replacing the battery, but the battery tests fine every time.
tjrob2000
Took the car to the dealer for diagnosis. Also asked them to diagnose an exhaust leak. Verdict is the current sensor is faulty. The alternator connector locking tab is also broken (Which I knew since it broke on me) and they wanted $843 to replace the sensor and connector. Sensor price from them I know is $106, so the connector is another $40 and then 4 hours labor. Ridiculous. I stopped them there and told them I'll pick it up and get the parts. I get to the dealer and the report also lists the alternator for some reason, even though their testing (from the printout I got) showed it to be fine. They wanted $2189 dollars to fix that! Then, the cat would be another $1736! Way too much. So, I've ordered the sensor for $47 from a dealer online and will get the cat later on, which is $608 dollars from the online dealer ($1317 from the local dealer). This is why I rarely take my cars to shops, especially dealers. Anyway, I'll have the sensor in a few days and will install it and see if that is really the fix.
They also noted the heater coolant hoses needing replacing. I can't find them in the parts online so may have to order them from the dealer. We'll see. I'm not sure how difficult a job they are to do so may have a shop do that.
tjrob2000
Update: Installed a new current sensor and first start battery light stayed on and would not go off with revving the engine. Reinstalled original sensor and battery light stayed on, but went off
after revving the engine.
To recap: problem started a couple of months after purchasing a new battery. Alternator was just over 2 years old at that time. Replaced alternator since there was no output when battery light was on so figured it had failed (replacement was a new Hitachi oem unit). Problem disappeared for a month then returned. Alternator was tested at place of purchase (electrical part rebuilder) and showed good. I got to see it tested. Reinstalled alt. and all was good for a bit. It is more frequent now, but I can always get it to start outputting by revving the engine (apparently getting the alt to self-excite). Been to 2 shops and a dealer. No good diagnosis to this point. Any other ideas I'd love to hear them. So far it's been crickets mostly.
audtatious
Sorry you are having all these issues and appreciate you actively updating this thread.
Infiniti adds a bit of nannyism to the system as the Battery current sensor looks for voltage changes at the battery and communicates to the ECM. The ECM then communicates to the IPDM E/R (the box next to the battery with fuses and relays) which then talks to the IC regulator in the alternator to set voltage values. Since nobody has been able to pinpoint the issue, and the battery/alternator may not be bad, then I would suggest going through the chg.pdf FSM and test each of the 3 other systems (current sensor, ECM, IDPM E/R) to see if you can further pinpoint it. Most of this testing starts at CHG-18.
tjrob2000
Thanks for the reply. I've been through the fam and took it to a dealer figuring they would go through all that. I also figured they would be better suited to send control signals to vary the output. So far all are coming up empty.
tjrob2000
Reviving the thread with an update. Had to have the car towed home the other day after the battery light simply would not go off and it died. I put the battery on my battery minder for a couple of days and battery voltage was now 13.2vdc, higher than it's ever been. Normally it's only gone to 12.67 or so. Started the car and battery light on. Checked alternator output and it is 12.21vdc, also higher than it's been. To make sure my meter wasn't misleading me I checked the battery on my other car and it is actually low at 12.1. Guess that one needs to go on the minder! Anyway, thought I'd try something to bypass the ECM/IPDM control and disconnected the control signal to the alternator. No change. Reconnected the control signal. I went back through bank records (I unfortunately don't have the habit of tracking when problems start, something to change on my part, but I digress) and I bought a battery in April 2018 then due to this issue starting I bought an alternator, after which the problem went away for some time before coming back. I've probably mentioned this before so if I'm repeating myself, sorry, but I think it's time to try a new battery.
Connections have been checked. Fuses checked. Alternator always tests good. Battery also tests good, but I can't help but wonder if it can still have a problem that isn't detectable with normal testing tools.
Tom
tjrob2000
Ok, battery didn't fix it. At least they swapped it so no cost attempt. Back to the drawing board.
tjrob2000
Update: after the battery swap I took the alternator to have it tested and it still tested good. Before reinstalling it I cleaned the hot lead (had been cleaned before, but what the hay) and sprayed contact cleaner in the control connector (I forget the actual name). Light hasn't been on since and that is now going on 7 weeks. Will keep monitoring and if it comes back....
audtatious
Good find. Hopefully that was the solution.
tjrob2000
audtatious wrote:
Thu May 07, 2020 8:29 am
Looking good so far.
tjrob2000
It's back!!! I've been driving the car regularly since 4/25 with no charge light issues. Get in and start it this morning (about 40 degrees this morning) and the light stays on. Obviously I haven't had a chance to look into it, just thought I'd vent. This is so frustrating! sigh......
telcoman
tjrob2000 wrote:
Wed Oct 07, 2020 5:25 pm
200
7 G35 Journey, 212,xxx miles. I recently had the P420 code come up so I ordered a new cat plus all 4 O2 sensors. I'm still getting the P420 code. I checked the O2 sensor voltages using a BlueDriver code reader and it shows the bank 1 sensor voltage is lower than sensor 2. Sensor 1 voltage is in the .45v range while sensor 2 is in the .78v range. Bank 2 sensors are behaving normally with sensor 1 at .8v and sensor 2 around .4v. Anyone seen the strange behavior I'm seeing on bank 1?
Tom
tjrob2000 wrote:
Sat Sep 14, 2019 10:03 am
'07 G35 Journey, 197,xxx miles. Only major work since I purchased it 5 years ago is the water pump. Done about 10k miles ago. Runs great!
An interesting problem!
I've read all of your posts and I believe the root cause of your problem is that you purchased a possible flood vehicle or a vehicle that had or has water damage?
Did you ever drive your vehicle with the missing fiberboard shroud missing from under your vehicle allowing water to splash into your engine?
When you did have your vehicle at the dealer did you have the dealer run the VIN number for a service record by the original purchaser?
Was your vehicle purchased outside the state where you live and did that state suffer any floods.
Here in NJ we all still remember Hurricane Sandy from 2012 where hundreds of thousands of vehicles suffered flood damage.
If we assume that your battery and alternator are good then the next obvious place to look is your wiring harness. Corrosion or a poor intermittent pin connection could account for your problem?
A fourteen year old vehicle with over 200k miles is near its end of life so I'm not sure why you want to continue to torture yourself with this ongoing problem?
Good luck in trying to solve the problem but perhaps its time to start searching for another vehicle?
Just my $.02
tjrob2000
telcoman wrote:
Sat Oct 31, 2020 5:07 am
200
Tom
Just my $.02
I purchased this car in 2013 in Sacramento, California and did get the service records, so no, it's not a flood car. I haven't driven it without the engine cover either. Also, at 200,000 miles a car is not necessarily at the end of its life (though my wife may disagree). I plan on rechecking ground connections again as well as the control connector this weekend. Thanks for the input.
telcoman
I also neglected to mention that I suggest that you check and inspect every wiring harness pin connection to the BCM, ECM, and IPDM. Perhaps there is some corrosion or a poor solder connection somewhere?
On my previous 06 G35 I had a repeating air bag warning light. After 5 or 6 trips to the dealer they replaced the air bag module and additional troubleshooting. Eventually the FSM called for replacing the entire wiring harness. That was a $2100.00 job. I was able to argue and the cost was eventually paid 1/3 by me, 1/3 by the dealer,and 1/3 by Infiniti.I had a loaner car for a month.
Never had another problem after the wiring harness was replaced.
Good luck
tjrob2000
So, I took the car to one more shop and they swore it's the alternator so I bought a used one (low miles according to the salvage yard). I started to replace it last week when I found the belt tensioner would not loosen and didn't seem to have the tension it should. Got a new tensioner (the old one I purchased in may of 2018, just 3 months before I bought the current "faulty" alternator) and installed the used alternator today. Charging light is off now. I'm going to get the other alternator tested, again, and if it tests good keep it as a spare. I think the bad tensioner was the cause, but I didn't feel like going through testing my theory today, just wanted to get it done. We'll see if this fix is permanent.
telcoman
tjrob2000 wrote:
Sun Mar 01, 2020 11:19 am
What are you using to test alternator voltage output?
Normal is 14.4volts
Engine running
Engine off
Test your battery
All six cells should show a full charge
One cell not accepting a full charge. I replaced the battery as it was over 4 years old before I had a problem
tjrob2000
The battery is new, less than 3 months old. I've used my DVM and when it is charging it reads 14.4, when not it is 11.6. Been to three shops and the dealer. Only the last indy said it's the alternator. Alternator has been tested several times off the car and found good every time. As I said, it's working now, but I think the tensioner was the real problem. I won't really know unless I install the original alternator at some point. Time will tell if all is well. Last time it was working it lasted about 3 months.
telcoman
You may have an intermittent or defective IPDM, Wiring harness issue, or the combination meter?
Is your vehicle garaged or parked outside?
https://www.nicoclub.com/service-manual ... %2Fchg.pdf
Have you read the FSM charging section?
See page Chg-15
Good luck
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
telcoman wrote:
Mon Dec 14, 2020 5:38 am
This sounds suspiciously like the infamous IPDM issue. See this thread:
topic623786.html
tjrob2000
I've seen a video about this "fix". I've never had to go 8 miles before the alternator had output. Given the circuit layout you would be driving with the charge light on that first 8 miles. If you are driving at night, with lights on, ac on in the summer the drain on your battery is pretty high. It doesn't make sense for any manufacturer to not have any output from the alternator for that long. I could be wrong, but from an engineering standpoint it sounds foolish. I'll double check with an Infiniti shop I know. This also would not explain why if I revved the engine sometimes the charge light would go off, even if only momentarily.
VStar650CL
Technical Expert
If there weren't known problems with the circuit then no one would need the "fix". A small percentage of these systems simply don't work as-designed, for reasons even the engineers don't seem to get. If you have chronic problems with low charge output, that will generally fix it at a cost of (maybe) 0.1 miles per gallon.
