ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Sun Jul 03, 2011 6:56 am
A/C on, clutch engaged compressor spinning, is it a V6 piston operated, feel the output large compressor hose, should be cold. That enters the evaporator which is the heat exchanger feeding cold air in the cab. The return line should be a bit warmer than the input line.
Feel these lines in am when cool, then again when in pm being warmer ambient. Are the the same or different in temperature.
Ambient does make some difference but when the freon changes state it does so when compressed. There is a plate within the compressor to vary the compressors rate of change, if stuck that compressor may only be able to discharge at the lower end.
Other than taking it apart and looking you can try dislodging the compressor's swash plate by giving it a good solid thud with a weighted hammer, but choose an area of the compressor that will do the best in vibration without breaking. This is a very iffy thing to do and should be done while the compressor is operating.
If a V6 compressor it is also expensive.
Also if you have a drier installed that drier may be saturated or plugging. Even the front mounted condenser can be plugged. Feel the heat exchangers both the internal evaporator and the front mounted condenser.
The evaporator under normal use is cold 40F to 55F while the condenser is hot as it removes cabin heat. So compare them, feel around the drier, while all this system operates liquid to gas to liquid transformation is taking place can you hear this, use a stethoscope on pipes and heat exchangers.
I am assuming you have no tools for really examining the cooling system so your hands, eyes and ears are needed.
The system is acting as if it is low on freon but I must rely upon your word that it is up, how did they test this?
