ILOVESILVIA(S13) »
https://forums.nicoclub.com/ilovesilvia-s13-u9905.html
Sun Jun 06, 2010 11:46 am
Hello all. I just got my car back from a local shop that fixed a previous problem I was having with my turbo and also an idling issue I was having. Well, they replaced my turbo, and fixed my idling issue, however I noticed something on the drive back from picking up the car. Once I picked the car up and was driving it home all was normal and the car ran strong. However, 20 minutes into driving I noticed that as I was accelerating the car started to stutter, pop, and generally felt sluggish. I then pulled over for a bit and stopped the car. I waited around and then decided to finish the rest of my trip since the shop was now closed. The weird part was that the rest of the trip was fine, the car ran strong again and had no problems. Fast forward to the next day. Same issue, car runs fine for half the day and then the problem comes back again. I end up calling the shop back and had them look over it again. They claimed that it was a wiring issue and said that they fixed it and checked all the codes and everything was fine. Well, again, like before, I picked it up and the same scenario happens again. The problem is that the car seems to run fine, and then this intermittent stuttering, popping, and sluggishness returns, but it only happens for a couple minutes or less, and then its back to normal. So I was wondering if anyone has had this issue, or knows about how I can get it fixed? Sorry for the long story. Also, if you need further explanation let me know.
ILOVESILVIA(S13) on Fri Jul 02, 2010 8:51 pm, edited 1 time in total.
