Intermitant Engine Knock...89 K24 Auto..
Mikelly
Guys, My son and I are troubleshooting his car. The motor has an intermittant Knock that is pretty persistant when sitting idle and when you rev it in park. When you put it in Drive you can feel it through the shifter in the car (Auto Trans), but when you drive it, the Knock goes away... Ideas???
Anyone else dealt with this?Mike :cool:
quiksilvia
Car: 95 s14 se
is it like a valve tap type of noise or what...
trpower7
More info will be needed. Knock can be caused by about 45 things. Info like where the noise is coming from, what it exactly sounds like, etc.
Mikelly
Guys, I've got a lift at my house, and I've had the car on it while it was running... It is coming from ALL OVER... LOUD, like a rod knocking in the crank and coming all the way up into the head, but not all the time...
Mike
