Tman Sr. wrote:I recently (last summer) replaced the fan motor it was blowing fusing on high. Actually the new (used from Mike goody) motor does the same thing but only on High and when the air conditioning is running, when heating it can run at High all day with no problems.
It sounds like you have more than one problem going with your Heat/AC system. Is your blower only running on high and can't be turned down to slower sppeds, or off? If so, there's nothing wrong with your blower motor (either of them) but it's the fan control amplifier mounted in the airbox behind the glove compartment. The blades on the motor you bought from me were cleaned up so it won't draw as many amps to do its job. Cleaned blower motor blades and cleaning the face of the condenser in the airbox will extend the life of the next fan control amp that you're going to need to buy. They're about $60 new (plus shipping) from IOS (Joe).
