pippen99 wrote:Same thing happened to my 03 coupe. You can spend an hour shoehorned into the footwell pulling fuses one by one or try this. Pull the positive battery cable, wait five minutes and reconnect. This will reset the BCU and cure your problem. It cured mine. If that doesn't work then screw yourself into a pretzel and have at the fuse block. Good Luck. (P.S. this will also kill your radio presets)
Well I'll be darned, but that worked!! Thanks a bunch.
I pulled the battery cables and took the opportunity to rough up the terminals and posts with a wire battery cleaner brush, and by the time I reattached them, the interior lights came on when I opened the doors! I can't imagine what may have caused them to go off in the first place, but they're back on.
Nick
